- Dec 23, 2011
- Colstrip, MT
- '91, '93
- Automatic
Yup, but you don't even need to worry about using studs. Just conter sink the cover and use some grade 5 or better bolts.
Just to be a nerd (an early, after Christmas Morning Nerd, so my math is probably off)...
Cliffs: I got a little wordy early in the morning, but if your diff cover has at least 2 grade 5 bolts holding it on, they're not going to get sheared off.
.....Math below....
Shear load failure is figured at 60% of thetensile strength (Grade 8 is 120 ksi, and Grade 5 is 85 ksi).
So you take the area of the fastener (we'll assume 3/8" bolts) A=Pi*R^2 so that A = 3.14*(.1875)^2... A=.1104 sqin for a 3/8 Bolt.
60% of 120 ksi (proof load) = 72 ksi. (Grade 8)
60% of 85 ksi (proof load) = 51 ksi. (Grade 5)
So the Capacity in Shear for one 3/8 Grade 8 bolt = 72 ksi * 0.1104 or 7,948 lbs woth of shear per bolt. Grade 5 is 5,630 lbs per bolt.
Now figure the pressure of the ram, we'll use a Huge 2" Ram with the a maximum rating of 3,000 psi (most PS pumps put out around 1,500 - 1,800 psi max).
Ram Force = Ram Working area * Applied Pressure
Ram Force = 3.141 * 3,000
Ram Force = 9,243 lbs
Figure in 10 bolts per cover or so, and you've got a pretty healthy safety margin there. The only thing I would be worried about is that cover getting worked lose over time. With counter sunk holes, RTV, and properly toqued bolts it a non issue.
If my math's offIts good enough for this
Nope, your math's dead on. I was thinking of the loose cover capscrews I've tightened during oil changes when I suggested studs. THEN, you could use nyloks and secure the bugger, once and for all. After all, the 'loose' bolts seem to work from one to the next when they start to loosen. Imagine the carnage if (un-caught) loosies came undone and either dropped out or sheared on a hard right with the tire against a big-ass rock.
And you wouldn't just want the bracketry out of the way for a gearset change. It'd be nice to have it open when you break a diff and have pieces to clean out and replace with something stronger. Like I said, I've been into a few of these and there's no good way to get them out if you can't pry the gearsets out or use the spreader to widen the case a skosch. A big, strong bracket would very possibly be right exactly where you need to put the heel bar.
But I guess there's always the air-arc...
freckles
