- Jan 5, 2009
- owensboro, KY
Ding ding ding.
let me try to explain my train of thinking... first, is there any disagreement that the diff cover is not the strongest point to mount it to? (i'm not asking if it is strong ENOUGH, i'm asking if there is a stronger place on there to mount it to) regardless if it's a stock or aftermarket cover... so if there is a stronger place to mount it to, why would you not want to mount it to that stronger place, if all it means is moving it an inch or so?
And now that the cherry's broken...Aside from the threadjacks and family problems that consumed a dozen or more pages, I'm astounded at the progress you made over just a couple months for most of what has happened. Especially considering the brutal weather you dealt with in your part of the world.
And then the daughter's problems 'encroaching' on your build time...man, I don't know how you've kept most of your sanity. A day at a time, I guess: just like the rest of us.
I do have a couple questions that I didn't see addressed. 1st, where did the 4.0/435 adaption come from? Adapted the big Ford bell to the 4.0 with a custom plate? Or adapt the 435 to a 2.9/4.0 bell?
And now that I've got thru the first few pages, I'm subscribed! Good work!
Newb chimin' in here...mounting the ram as pictured will keep the front of the diff easily available for gear changes. Speaking as a guy with 'way too much experience setting up Danas, you'd want as little crap as possible in front of the opening. A honkin' big bracket welded to the long tube and angled over the cover would be really inconvenient to get a gearset around. The bracket being built into a very heavy duty diff cover should work just fine. The only thing I'd do additionally is use studs instead of bolts to mount the cover.
If the bracket is made on the diff cover, then all that will be needed to do is pull the pin for the ram, swing the ram out of the way and then pull the cover, there will be no extra bracket to remove, since it will be part of the diff cover. And I second the stud kit for the diff cover...
SVT
Its good enough for this Ok Ben, who did you copy this from
SVT
