What size bolt do the ruffstuff 3/4's use with the misalignments installed?
you have a straight axle now?
I am using 3/4" bolts, took all the misalignment spacers out except at the pitman arm. I will have double shear at the pitman arm, and I have doubler shear at the tie rod end of the drag link, then single shear right now at the knuckle, but 3/4" bolts. I will get pictures if you are interested.
Pictures
You get the idea, but it is all 3/4" heims, with 3/4" bolts. The pitman arm is still cooling at work so it isn't on, but it will be a 5/8" bolt in double shear. The tube is 1.5" dia 1/4 wall DOM. I will thrash on it this weekend and let you know how it goes, but so far it feels great.
