PlumCrazy's Build
You need to find a gear reduction box.
Sent from my PC36100 using Tapatalk 2
I looked, but everything I found is too damn heavy duty and bulky. I may look into a different motor, like a gear reduction starter or something.
-PlumCrazy
Why not mount the York under the hood and run it off the engine?
I have the PERFECT gear reduction box for you but Im using it on my meat grinder lol. It's around 4x3x6 inches. I believe
No room, I am not giving upy AC.lol. I find a remote reservoir for my Saginaw then I may be able to squeeze it in. But i looked and never found anything that would clear the AC bracket.
-PlumCrazy
I may build one, I have access to a mill and a lathe.
-PlumCrazy
why not find two gears that will fit on the motor and pump and use them that way, just have to stack the motor and pump, and also spray grease on the gears every now and then.
Robert
posted using the power of 2x2=6.
Robert
Thought has crossed my mind too. I would like to find some nylon/Teflon gears to use.
I won't be able to stack them though, the box isn't tall enough.
I also found 2.5 hp motors that are aftermarket replacement motors for Ramsey winches. They have a 3/4" shaft and are smaller over all than my current motor.
-PlumCrazy
I don't want to spend too much money on this though lol. Id rather put it towards something I need more, like chromo front shafts.lol
-PlumCrazy
FYI, I only have $60 or so in mine.
I only have 50 or so in my current setup, but I want something a little more robust.
What are you using for a compressor?
-PlumCrazy
Just the stock ranger sangren* pump
The York should be able to put out more CFM than a stock comp. I like running the electric motor because I have the ability to have air when the truck is not running.
-PlumCrazy
3 Day weekend was full of progress.
Built new radius arms that use Johnny Joints and have 10* caster built in.
PlumCrazy's Build
PlumCrazy's Build
Modified the old brackets to accept the JJ.
PlumCrazy's Build
PlumCrazy's Build
PlumCrazy's Build
Started working on chopping down the coil buckets for new shock mounts and Heep coils.
PlumCrazy's Build
PlumCrazy's Build
PlumCrazy's Build
PlumCrazy's Build
PlumCrazy's Build
PlumCrazy's Build
Now I need to swap my 7* bushings for some 4* to get a better pinion angle.
PlumCrazy's Build
-PlumCrazy
Wow, you were busy. Looks good Plum
