Please Help,88 ranger wont start
SlaughterhouseSean
I posted under the same title about a week ago but I am reposting because im not sure it is still getting views and I could really use some help, Original post is under the same title posted in general discussion and under 4 cylinder(2000 and older). Ok, im about ready to roll this truck off a cliff,lol. I have checked the battery, its getting 12V,tested it with key on and it dropped to 11.7V, have replaced starter, starter solenoid,ignition switch and for some reason I am still not getting power to the starter. Thought maybe NSS, went to autozone and they didnt have the right part, in this model it is the clutch pedal position switch, went to orileys and the one they had was similar but not the same and was $40 so i decided to just try to bypass it to see if it is even the problem before buying, looked up a video and im pretty sure im doing it right but not positive, STILL NOTHING! I dont understand how im not getting power to the starter after replacing all of this. I dont have experience so any help would be appreciated.
I saw that this issue was fixed on one post it was the igniton wiring was wrong are you still having issues??
Sent while eating tacos
Find someone to operate the ignition while you hold a test light connection to the small terminal on the starter relay, and the other end to a known good ground.(check the light will light by touching the ground and the + terminal of the battery at the same time)
Have them turn the key to START. If the light glows, you have power to the starter relay(near the battery under the plastic cover). The relay should click/snap when you put the terminal back in place, and have the remote starter person move the key to START once again. If it does, then the safety switches, neutral safety(MLPS in 'new' terminology) or the clutch pedal switch are working. MLPS=manual lever position sensor.
If the relay won't do anything, or the light won't light, you have a safety switch problem or an ignition switch problem.
The ignition switch is mounted atop the steering column, down a bit from the lock cylinder, connected and operated by a rod. When you turn the key, the rod moved the internal bits of the switch to connect things as necessary. If the switch is defective, worn out, or is coming apart(which they do when they get old), it may not be making the contact needed. Remove the column cover (three Philips screws in most cases) and take a look at the switch & operating mechanism.
tom
