PCV Valve Replacement
ford4wd08
Alcoa, TN
2.8 V6
This is a very trivial question to most, but I have a quick question.
Are there different styles of PCV Valves? I'm looking to replace the one on my 2.8 v6, but I don't see one that matched what I currently have online at auto part stores. I think I'll also need a grommet as well as there isn't much left of mine.
I attached pictures of the ones I'm looking at.
You have the factory ford ones I like the plastic ones over the metal ones you could go out to the junkyards and pull a few off the new ford rangers they really never go bad the rubber garment Is the same one they used for the power brake units I think or they look a lot like them Put you can find them at any auto parts store
I'm thinking my hose needs to be replaced as it keeps slipping off. And the grommet doesn't seem to seal it well.
Just trying to avoid all vacuum leaks if I can.
