Oh ok! So I'm guessing my truck doesn't need the little hose then?Yes, that is an old one from the bad ol' days of carbs, probably previous owner had one(or a few) laying around
All engines run with the same vacuum levels, 18-21" so all PCV valves are the same internally
You just need to match outside diameter so it fits snuggly in the rubber grommet, which is also pretty standard
Most replacements these days are 90deg and have a larger and smaller hose connection
And come with a plug to plug the smaller one if its not needed as a vacuum source
So any of the ones shown should be OK for you
May need to get a different hose if the 90deg doesn't work
