Old Reliable Ranger Cranks But No Start
e21pilot
My 1992 4.0 V6/auto extended cab Ranger was running perfectly except for the occasional bouncing of the volt meter when idling. I was going to get around to testing the alternator but never got a chance. Today it cranks but won't start.
It sounds like the fuel pump clicks when the ignition key is on but I don't hear it running for a few seconds like it always does. Any way to test for power at the fuel pump without removing the bed to get to the connector? I suppose I could depress the Schrader to see if there is any pressure in the fuel rail.
Beat of the bottom of the fuel tank and then see if the fuel pump will run. This is a very common trick that works with a iffy fuel pump, especially if you are stuck on the road somewhere.
If it works, then you know you will need a fuel pump. Try to get as much fuel as you can out of the fuel tank if you have to change the pump.
