- Sep 9, 2007
- Age
- 86
- East Texas
- Automatic
Prove it...........
Prove it...........
Prove it...........shady
wix/napa or motorcraft for me. if i have low oil pressure, i fix the problem![]()
Shady, you aren't an engineer either, but anybody with just common sense can tell by the construction analysis that the Fram is inferior!!
On my old 2.9L I ran Fram for a while (prior was Wix or Purolator) and my truck began to tick upon cold start; not long, maybe ten seconds, but enough to bother me. Next oil change I tried a Mobil1 filter and the problem went away. Kept with Mobil1 and never had the noise return the rest of the time I had that truck.
You havent' shown me anything, sludge. No data, none
When I read these posts, very few have actually had problems. It is always "I knew a guy," or "a friends car," or "I had an uncle." Seldom a first hand experience.
smart remarks (referenced above) to novice mechanics....don't crack on people or make smart remarks for people having their own opinion.
Yes, I read your "experience." You had one experience with what you believe to be attributal to the filter. And from this one experience, you condemn all products made by this company. Good thinking there, Bob. Using this logic, I will never again use Motorcraft spark plugs. Personal experience. Changed plugs in my F150. 2 weeks later engine started missing. One of those damned, good for nothing, pieces of shit Motorcraft plugs failed. I'll never use those damned things again.I've already told you my experience,
These links are just forums like this one. Not proof of anything. Same old stories, just different people telling them about something they read on the net, or someone they knew, or heard about. Only a couple mentions of anyoe actually having problems. And, just like this forum, we don't know the particulars of what happened, and I am not big about taking anyones word about anything. If you had any experience in the auto repair business dealing with customers, you learn not to believe a damned thing until you see it yourself. Give me some actual proof of catastrophic failure of Fram filters in a number that would have some significance, then I will listen. Till then, I go with what I know.:shady
What was the engine damage that resulted in the "dozens" of bad filters you replaced? There must be lawsuits abounding where you live from these bad filters. It must be local as I haven't hear anyone else relating these problems. Or, maybe these filters weren't bad at all, and were still doing their intended job. Who knows??????when i spin a filter off of a vehicle and shake it, and hear the filter element rattling around loosely inside the canister...thats bad. period. its a fact and its not rocket science. i have had this happen with DOZENS of fram filters.
Or, maybe these filters weren't bad at all, and were still doing their intended job. Who knows??????shady
As documented in the contruction analysis, Fram's anti-drainback valves SUCK!!!
I wan't "implying" anything. I asked about engine damage from the "clunking" filters. No answer.are you actually implying that a filter with an unattached filter element clunking around inside the canister ISNT "broke"?
Yes, I am right in my experience with Fram filters.ok shady, your right.
Don't put words in my mouth. I didn't say any such thing. I know there have been some who have had problems with Fram, and Delco, and Motorcraft, and all others. No one filter, or manufacturer is perfect. They all have their problems. What I am saying is that most of those blaming Fram are doing so from mostly heresay, not personal experience.fram filters are definitely the greatest thing since sliced bread. everyone on the internet all got together one night and decided they would all try and make fram filters look bad "for fun" and there is absolutely no truth behind any of the claims.
Again, I am right as far as my personal experience goes, and that is all I have to judge by. I am not going to jump on the hate Fram bandwagon until I see some VALID evidence in such numbers that they have enough of a problem to be concerned. And if you turn in those dozens of bad filters, it might help.and your record of always being right (and your ego) still stands. congratulations.
you would be a hero.
