odometer quit check engine
Featured Build Threads
flaskaworld
10+ Year Member
tachometer quit check engine
I need help desperately. I'm on vacation, driving cross country. I fueled up and upon leaving, I noticed my tachometer wasn't working. Within minutes the check engine light came on and it started sputtering like it was going to stall. If I shut it off, it runs fine for about two minutes. Till no tachomerter though. I've been driving for hours with no problems then all of the sudden.... Anyway, 94 4.0L. I could use any help. My dad's a mechanic in MI but unfortunatly he's unavailable and I'm in CA. I'm not the best with trucks so any advice would be very helpful.
If I had to guess, I'd guess Ignition Module (ICM).
It is a common failure item and provides the electronic signal for spark and tachometer.
You should find it on the radiator support, near the driver side headlight.
Event Coverage
Featured Ranger Based Vehicle
