- Jun 30, 2008
- Age
- 35
- Summerville, SC
- Automatic
is there a way to remove the o2 and trick the computer into thinkin its still readin good?
Hook up a resister that matches that of the voltage of the O2 sensor's output.
Nick
i cant imagine why anyone would want to bypass the O2 sensor...
because he plans to pull his cats, and this will cause the o2's to throw a code?
Goodness gracious!
1. Why the F do you post crap if you don't have a clue?
2. First question: how do you set the voltage of a resistor?
3. Second question: how do you make a resistor switch upon command from the PCM?
All you have to do is wire power to a resister, then to the computer so it thinks there is voltage being generated, but it is just a lowered voltage from the vehicles 12v electrical system.Wikipedia said:A resistor is a two-terminal electronic component designed to oppose an electric current by producing a voltage drop between its terminals in proportion to the current, that is, in accordance with Ohm's law: V = IR. The resistance R is equal to the voltage drop V across the resistor divided by the current I through the resistor.
