skinner
It's hard to say just how accurate that test is. In cases i've encountered, it usually had to do with them getting 'stuck' and basically not being able to stay idling and even die when started cold.
Unplugging a sensor should revert the computer to use a default value which is never right but hopefully "good enough".
I'd still try cleaning the MAF with MAF cleaner first, clear codes, and keep your fingers crossed.
Most MAF's these days come in a metal housing, that hooks to the airtube near the a/f yes...and on fords the physical sensor is held into the housing with starhead bolts with nipples on them(called tamperproof or security starheads).
