Featured Build Threads
If you do a lot of heating and cutting, look into propane tips, and hose certified for propane, for your cutting torch. A lot cheaper than acetylene.
Thank you. I've heard of using propane with the oxygen. But haven't looked into it yet. That will come later.
In preparation for the transmission replacement on the Escape, I ordered one of these.
And a thread chaser set.
And in preparation for the timing cover leak on the 2019, this. Because of the non-indexed crank pulley on the 2.3 engines.
...non-indexed crank pulley...
I'm pretty sure that's in the running for the dumbest things ever said. Right up there with, Wa Chiss!
Yep, apparently, that's been a thing with the 2.3 for a while. It's a press on fit with the pully bolt and is timed with a specail tool off the crank sensor and the notches in the back of the pulley. Stupid design.
Finally used that vevor welder and the new mask that I got with it.
Got everything out of the box, set up was very easy. Came with a little spool of flux core, which is what I ended up using because the hose connections for the tank were lame, and I couldnt connect my CO2 tank to it.
I've barely used my Miller 100A welder, and never welded before that, so my thoughts are as of a total noob when it comes to welding. My baseline welds are BAD, so assume these thoughts are coming from someone who has no idea what they're doing, but is looking for seat time
The mask is nice, much nicer than my older cheapo mask. Large field of view, fits my classes better. I'm still not happy with how I have it adjusted yet - having trouble seeing where I am on the piece, so I'm drifting a bit. For a cheap mask, the response is quick and after welding for a few hours on Sunday my eyes weren't burn at all, which is really nice
I ran it to the 220 circuit in the laundry room with an extension cord into the garage, about 25 feet in total. I ran everything with their MIG pulse settings, though I felt like wire feed is a little faster than my newborn baby welding brain can process. For the price, I like it a lot more than the 100amp 110v Miller I was trying to use. I had an adapter come yesterday so I can use my CO2 tank to give that a whirl and see how it looks doing regular MIG instead of flux core.
I think someone who knows what they're doing but is looking for something versatile and cheap would like it. I'm happy to learn on something that burns in a little better and will stay with me a little longer I think. We'll see how long it lasts, but for $230 I'm very happy
Featured Ranger Based Vehicle
