Featured Build Threads
If you do a lot of heating and cutting, look into propane tips, and hose certified for propane, for your cutting torch. A lot cheaper than acetylene.
Thank you. I've heard of using propane with the oxygen. But haven't looked into it yet. That will come later.
In preparation for the transmission replacement on the Escape, I ordered one of these.
And a thread chaser set.
And in preparation for the timing cover leak on the 2019, this. Because of the non-indexed crank pulley on the 2.3 engines.
...non-indexed crank pulley...
I'm pretty sure that's in the running for the dumbest things ever said. Right up there with, Wa Chiss!
Yep, apparently, that's been a thing with the 2.3 for a while. It's a press on fit with the pully bolt and is timed with a specail tool off the crank sensor and the notches in the back of the pulley. Stupid design.
Upcoming TRS Events
Featured Ranger Based Vehicle
