Need VSS wire on 2006
dhdaniel
Baytown Texas- Gulf Coast
2.3 EcoBoost
Installing cruise control, I desperatly need help locating the VSS wire,
Supposedly its in this connection harness ECM?
according to the documents it says a 2006 ranger VSS is located
3 CONNECTOR ECM
MIDDLE CONNECTOR POSITION 1
Purple/RED
I don't see any 3 connector ECMS, nor any Purple Red Wire
thanks for any help
Dave
It should be in that plug, try position 68 and it should be Gray/Black. Its been awhile, but if I remember right its in the third row. Each row has a small (and I mean SMALL) number at the beginning and end of each row.
There also might be a second location. Check out this post, the first post.
http://www.therangerstation.com/forums/showthread.php?t=24850
The second picture is the factory criuse plug, if its there then the Gray/Black is the VSS wire
