- Feb 13, 2025
- Age
- 52
- Kansas
- 3.0 V6
- Automatic
- Tire Size
- 225/70/15
2001 RWD 3.0. Code P0460, truck only stays running with jumper cables hooked up. On the cluster, the temp gauge doesn't register, the fuel level works, no RPM's, no oil pressure reading, no battery voltage reading. Remove cales and the voltage drops fast! Whats going on here? Inhave a Topdon scanner and can post readouts if needed.
