Need OBD-II Trouble Code input
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS Banner 2012-2015
GMRS Radio License
TRS 25th Anniversary
Nocona
TX - USA
Other
2005 Jaguar XJ8
Vehicle
Drive
2.3 EcoBoost
3.5-inches
p0171: was a bad fuel injector also causing a dead misfire
p0400-p0404: DPFE sensor almost everytime lol
p1000: sets after codes are erased or battery is disconnected
p1051: you have to push the brake pedal down during KOER test, if not this code will set or the brake circuit has a problem
p1404: usually only on california vehicles, i've had a couple that the temp sensor was completely covered in carbon or the EGR passages were plugged
p0551: power steering switch had fluid leaking into the connector, replace switch.
thats all i feel like remembering right now lol, i just went down the list to see if i've dealt with any
Hey Jim (Assuming you have e-mail notification on this thread).
I have found the "GOD" Book (Sorry if this is over the top), it's an 85 Mb. PDF on Ford injection and computers,
Some 442 pages !!!!!!!
Because of it's size I would have to put it up on my web server so you could download it.
It's got "everything, about everything"...................
Let me know.
Greg Manning,
Brandon, Mb, Canada
^^^Would this be appropriate info for the backyard mechanic trying to learn obdII ?
If so, would you be willing to let me copy it?
Thanks,
Richard
p01443, purge valve code.. almost everytime its the sensor or the solenoid... always be sure to check your pins i have seen them get the green disease
Got it.
Sent from my SGH-I747M using Tapatalk 2
The PCM monitors voltage drop to determine coolant temperature. If the ECT reads less than freezing temp. when engine has been running for more than a few minutes, the PCM determines a circuit fault and sets this code. Or if the PCM determines the sensor resistance is out of specs, this code is set.
:icon_hornsup::icon_hornsup::icon_bounceblue::icon_bounceblue:
So my truck is throwing up P0153, P0174, P0133 and last but not least P1152. Any suggestions as to where I can start?
