RideFord94
- Dec 28, 2013
- Automatic
So I've made an extensive amount of airflow mods to my motor. I can elaborate if any would like, but the real subject here, is that I was reading on rogue performance that through a certain formula. He was able to assume that the stock ranger injectors at 14 lbs can support maximum of 150 hp N/A even less with induction. Now, I've swapped my original motor with a 97 windstar 3.0. Through research I've discovered that these are 17 lbs injectors. So I've also read that most ecu's can self tune for an injector up to about 20% larger. Does anyone know if they are plug and play, or is there more work involved than it seems. I believe this to be a staple in the usual ranger modifications IF IT WORKS, because if you were to add 5 - 10 hp your injectors wouldn't be able to handle the additional horsepower. Thereby making any mods effectively useless. Any thoughts, ideas, concerns, complaints?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
