Need help
Featured Build Threads
DavidWalter
Forum Member
EPWORTH
GA - USA
Vehicle
Drive
I have Mazda B3000 truck 4x4 (same as Ranger) putting ball joints in had pull front axle out passenger side right side I desperately need diagram showing were the dust seals and grease goes on axle and spindle in detail better still names and part numbers.
Can't get top ballpoint to come through straight got little bit angle when come through is this normal?
Balljoint
sorry Ball joint
Are you using a jack to push up the lower control arm? If not, you are never going to get it in the knuckle. You need to bring the knuckle to the upper control arm, not the control arm to the knuckle.
if you have the spindle angle of the ball joint close, nature will take it's course on the rest.
If I'm reading this right, the angle on the upper ball joint is always gonna be there. It's the alignment for that axle.
Just to help. This is like what you're working on, right?
Need help
Nope. Haven't seen one that clean and rust-free since the day I drove my brand new '88 F150 off the dealers lot in Nov. '87.
Is this some kind of AI tomfoolery?
That was before I put the axle in the truck. It's not that clean now.
Edit: July 25th 2014.
Featured Ranger Based Vehicle
