Need Help
Featured Build Threads
BroncDueceLV
I've had my Bronco 2 for a few months now and have been trying to do most the problem diagnosis and repairs myself, however, I have very little mechanical experience. I have an 88 manual 2WD Bronco 2 with no modifications and I was wondering if anyone new where to start looking with the following problems:
Speedo and Odometer randomly stopped working, all other electronics seem fine.
Oil pressure runs a little high (close to max) especially at highway speeds. I had an oil change a few days ago and it did not help.
Truck recently (2 weeks ago) began rumbling at idle, when I first bought it this was never an issue.
Occasionally coming out of first the truck gets close to stalling, this issue seems to go away after it runs awhile.
The speakers blast a lot of fuzzy interference.
Engine Block appears moist, maybe needs to gaskets? but I do not get drips below the vehicle.
I have replaced the battery, the upper radiator hose, the oil pressure sender, the multifunction switch, and a vacuum hose going from the fuel pressure regulator to the engine. Otherwise the vehicle is completely stock as far as I know.
Any help would be greatly appreciated.
Speedometer is mechanical cable on the '88, so could be the cable or gear in trans.
If it has Cruise control the cable runs to it in the engine compartment and then to the gauge.
Odometer runs off same cable.
'88 should have an oil pressure switch not a sender, it closes above 6 psi of pressure, so grounds the gauge, if oil pressure is above 6 psi then gauge just sits in the middle, if it moves at all that would be from the electrical system changing voltage, not oil pressure changing.
Gauge is essentially an idiot light with a needle instead of a bulb :)
Make sure you got the right "sender".
The TFI ignition system can get flaky when it gets older, always good to run a test on it when engine power has issues:
http://www.therangerstation.com/tech_library/TFI_Diagnostic.html
Audio system can be effected by the spark system, does audio sound funny with engine off?
Could just be antenna is loose or disconnected as well
The "rumbling" could be a lot of things, an exhaust leak perhaps? Even a pinhole will make a noticeable difference.
Factory speakers were pretty terrible in the 80's, mine are literally falling apart. The paper cones turned to dust. Dirt and stuff collect on top of them too so you may have some buildup... just replace them with something better.
Thanks for all of the help!
So apparently the vacuum line I replaced connected to the fuel pressure regulator is never supposed to have gasoline in it, which it did, which is how I found out it was cracked and why I replaced it. Told you I wasn't mechanically inclined. Anyway... the gas was in the vacuum hose due to a faulty fuel pressure regulator. I replaced the regulator and the bronc is purring like a kitten, no chugging or rumbling.
Do I need to get under the truck to access the transfer case where the speedo cable is located? How do I find it?
I will fidget with my speakers on a day off and see if I can figure out what is wrong.
Thanks again for all the assistance!
The diaphragm in the FPR had a hole. Used to be a problem with mechanical fuel pumps. The vacuum will add extra fuel to the intake. Check the dipstick for gas. If the oil level is high, the oil runs off the stick rapidly, you can smell gas or are able to light the stick on fire, then the oil is gassed. Change it ASAP. Not only does your rig run better, the MPG will go up a little too :D
Those gas issues mentioned above. were from the days of yore, When engines had mechanical fuel pumps, carbs with hand chokes, 6 volt Positive ground ignition systems. etc. :D
Featured Ranger Based Vehicle
