Need Help
RangerDannyG
Gallup,NM
I plan on buying new Goodyear wrangler MT/R's with kevlar.I was wondering if anybody knows if 265/75R16 size tires will fit a stock 2009 ford ranger sport 4x4 supercab??? Or should i raise the suspension first?
That's the same size as I ran on my '05' ext cab 4x4, stock. Barely touched the plastic inner liner at full lock.
Dave of the Nord
Thanks guys , im planning on trading in my 96 for the 09 , then im gonna start working on turning it into maybe a pre-runner style truck im not to sure .
I have another question , on my 96 when i start my truck it sounds similar to the sound it makes when you turn the key,when its already running . any idea what is causing this?
like the starter motor running or the fuel pump priming?
Im not to car savvy but ya i think its the starter, the truck starts right away but the starter sort of screams .
how big can i go with tire size ,with a 4 inch lift on my 96 ranger?
Im going to refer you to our tech library ^(above)^ so you can do a little reading and find out all the information that you need is w/in your grasp.
In my honest opinion, if you're making a prerunner ranger, stick with the 96. It's tons cheaper to get results with the older style suspension.
Sorry if im bugging , (i feel i am ) but after consulting with my local tire guy , he told me i can fit 235/75r15"s on my stock suspension. my concern is ,( if i get a 2in leveling kit for front and 2inch blocks for rear) , will the tires look too small.
