Need help with part numbers for u joints
Hectron
Firefighter
EMT / Paramedic
NC
2.9 V6
Hello everyone. I’ve tried to search for part numbers for the u joints for the front axle of my 1987 Ranger. It’s a standard cab 4x4 108 wheel base. From what I’ve been able to see in the repair manual, I need 2 for the right side and 1 for the left, but I can’t make sense of which ones to get and the people at the parts store are of no help. Thank you all in advance.
I looked on rockauto, this is what they list for the front axles.
SKF UJ466 Greaseable; Brute Force
ACDELCO 45U0122
MOOG 436 Non-Super Strength
ACDELCO 45U0183
MOOG 466 Super Strength
SKF UJ436 Non Greaseable; Brute Force
I remember doing these about a year ago on my Bronco II when I did the balljoints. These are the smallest u-joints I have ever messed with. You can google any of those numbers and see if anyone else has them.
Awesome! Thank you. Just to verify, I just need to buy 3 of any 1 of these parts and I’m good to go?
That's correct... three of them. I am fairly sure RockAuto's cross reference on some of those is incorrect, those small u-joints definitely do not fit anything made after 1989 (not that it matters for you though.)
If you wanna be absolutely sure, the driver's side is the short shaft and comes out easily enough. Just wheel, brakes, bearings and spindle. 16 nuts/bolts in total.
You might be able to measure one between the ball joints.
