need help finding door hinge pin and bushing kit
87RangerXLTct
Connecticut
Stock
Stock
235/75/r15
tried rock auto,autozone, advance and some other parts stores and nobody lists a door hinge pin and bushing kit for a 1987 ford ranger. My drivers door is sagging and i'd like to fix it. anybody replace there hinge pins on a early ranger or bronco II and have a part number that will definitely work?Thanks
nope thats the roller. I need the hinge pins and brass or bronze bushings usually come 2 pins and 4 bushings in a kit. I've done this repair on my road runner and had a easier time finding a kit for that then I did my ranger.
I seem to remember seeing a generic kit in the "HELP" section of my local parts place.
My Explorer did this a few years ago. I found it easier to hit a local Junkyard and get the whole hinge. Unbolt the old, put the better one in and go.
^This...
I recently swapped the doors on my 88 with some from a 92...main reason...the 88 had a broken part that I could not otherwise replace...it was the lock open tab on the inside of the lower hinge...this prevents the door from closing on you and/or cracking your shins...
The whole hinges are also available in Canada last time I checked...and the price wasn't too bad...under $50 IIRC...when you compare that to the hours you spend driving around to parts places, gas, food...well, you know how it can add up!
