- Feb 13, 2025
- Age
- 52
- Kansas
- 3.0 V6
- Automatic
- Tire Size
- 225/70/15
Bought this truck with 101k and zero maintenance has ever been done. It's a 2001 RWD flex fuel 3.0. Started on the maintenance items due to rough idle and failure to start at times. Runs pretty good now, but still has a rough idle once in a while. So far I have replaced the items below, but today, I have gotten a P0172 repeatedly after clearing it twice.
Tests so far include the dry fire injector test (turn ignition to start, hold down gas pedal, turn ignition to run) and the truck just cranks, let off gas pedal and it starts right up. I have seen that is a test for leaky injectors.
Inspected and sprayed brake cleaner near all vacuum lines, no change to idle speed.
Unplug IAC and truck idles down but still runs, plug in and it idless back up
Transmission fluid and filter - Wix filter & gasket and Motorcraft Mercon V fluid
IAC - Hitachi
Coil, sparkplugs, plug wires - all Motorcraft
Cleaned MAF and Throttle body - removed throttle body for this
Cam position sensor and Cam Synchronizer - Motorcraft
Air Filter - Wix
Fuel filter - Wix
Oil and filter - Pennzoil full synthetic 5W20 high mileage and Motorcraft filter
PCV - Standard Ignition
Coolant flush, new thermostat and temp sensor, both Motorcraft, Prestone antifreeze
Both upstream O2 sensors -Bosch
I have read to swap the 2 new O2 sensors with each other to see if the code switches to the other bank, to replace the upper intake plenum gasket, replace the MAF, etc. I just want to know what tests I should try using a nice scanner I am getting from my son tomorrow. I think testing STFT and LTFT tells a lot from what I have read, but I don't know how to interpret those results. All help is appreciated!
IAC - Hitachi
Air Filter - Wix
Fuel filter - Wix
