My new project - 03 Ranger 5.0 Swap
97Ranger3.0
5+ Year Member
Louisville
KY - USA
3.0L
4"
33x12.5
Some of you guys may have seen thread on my 97 4x4 "build" on here. I still have that truck and it is great, but I've really been wishing I had more cab space, and a less sluggish truck lol. I also don't feel that I need 4x4 anymore and want the simplicity of a 2wd truck. I've also been itching to have some sort of fun project, so I thought building a 5.0 Ranger would be a great first project like this for me since it's mostly a bolt in swap.
I've been looking on facebook marketplace for maybe a month or so and finally found what I feel is a great candidate for this project. It's a 2003 XLT 4 door, 4.0 auto. This one is overall in pretty great shape and very rust free. I like that it is a 4 door (although I need to fix the cables so they actually open correctly lol). I like that it has power windows and mirrors, and the interior is in really good shape. Also a funny coincidence it happens to be the same color as my 97.
The plan is to eventually find a donor 5.0 Explorer for this truck, and also do a 5 speed swap with the m5od-r2. Until then there's some minor cosmetic stuff I need to take care of and a bunch of TLC needed.
First thing's first I got rid of that ugly ass hood scoop someone stuck on there.
This 192k mile 4.0 leaks oil out of just about every possible spot. Supposedly it had valve cover gaskets replaced, but when I inspected the truck before buying, it appears that it also may need a rear main seal or oil pan gasket. I don’t want to put much money into this 4.0 since it's coming out eventually. So I figured I'd throw a new PCV valve in it to see if maybe the old one was just clogged and maybe this was contributing to the oil leaking from just about everywhere. The old one was definitely gnarly so we'll see if this helps at all.
I also noticed that the trans dipstick was loose, and upon further inspection it was not even seated in the transmission and just hanging around the engine bay lol. So I fixed that this morning. There is definitely a combination of engine oil and trans fluid underneath the truck just about everywhere, and one or possibly both are leaking onto the exhaust and making it smoke when you drive as it burns off. I'll have to drive it for a bit now that I've fixed these two issues and see if it has at least improved before the eventual swap.
I somehow didn't notice this until I got the truck home though lol :rolleyes:
I'm guessing that this side drum brake was locking up or something so someone just capped the line instead of actually trying to fix it :mad:. I did think the brakes weren't great when test driving it but I would've just guessed they were worn, not that I was only using 3 of the 4 brakes! So new brakes plus fixing this line and a fluid flush is on the list. And the truck needs outer tie rods and new front bearings as well.
Otherwise, the truck runs and drives fine and I drove it home about 2.5 hours away with no issues. Another thing I'm considering is whether I want to go with either a 3" spindle lift and 31s or maybe try a 2/3 drop and some larger wheels, although I'm not usually a huge fan of how extended cabs look lowered.
Now to find a good donor Explorer...
Between fixing the transmission dipstick and replacing the PCV valve the truck no longer smokes while driving so that's good. The truck desperately needed new front bearings and tie rods, so I just went ahead and installed new brakes, bearings, inner and outer tie rods.
I should've removed the drum on the side with the brake line removed before ordering new drum parts because it was worse than I thought :oops:
This is after removing the drum. There were no shoes or hardware inside. Just the exploded wheel cylinder. I'm honestly very curious as to what happened. I did come prepared with new wheel cylinders, but the backing plate was pretty mangled and needed replacement which I was not prepared for lol. So I decided to just say F it and go for a disc brake swap.
In the meantime I fixed the cable ends for the rear doors. You could open the doors by pulling on the cables but the handles didn't pull the cables enough on their own. But now it all works like it should!
After a few weeks my Mustang brake parts showed up. Not gonna need this anymore!
Passenger side installed.
I bought the Currie CE-6013E hose kit I saw recommended on here. Unfortunately the mounting tabs that are supposed to come with the kit were missing from mine. I reached out to Summit about it and they said they'd get some sent to me but they haven't arrived yet and I didn't want to wait any longer to fix the brakes so I just made my own.
They're not pretty but they'll certainly do the job.
And here's the other side complete. It was getting late so I decided to not set up the parking brake, so that's a project for another day.
Side note about the Currie hose kit. In my opinion, I don't see the kit being worth it. I was disappointed to find that it's just Dorman brand hoses. I believe you could get those hoses, some retaining clips and make your own mounting tabs a lot cheaper. Also considering the fact that the banjo bolts in the kit are the wrong thread, and if you get unlucky like me and your calipers didn't come with the banjo bolts then that's another expense to consider. Anyway, here's the part number to the brake hoses from the Currie kit if this helps anyone.
Looking for some advice regarding the Mustang parking brake.
From what I had read on here and seen in YouTube videos, you're supposed to hook the factory e-brake cables up, measure the distance between the flange on the caliper where the e-brake cable should lock into vs where that same point is on the Ranger cable and make a spacer right? So initially I did this, the driver's side was 2.5" and the passenger side was 3". With this, the main cable had a decent amount of slack when the parking brake wasn't engaged and when engaged the parking brake didn't hold really at all (some movement on the lever on the caliper but not much).
So I went back and added 1/4" to each spacer, so 2.75" on the driver's side, 3.25" on the passenger side. This took a lot of the slack out of the main cable when not engaged, and it took a bit of effort to hook up the cables to the calipers. The parking brake improved but I'm still not feeling that it's as good as it should be. I have to put the pedal all the way to the floor for it to do any real holding. I don't have a lot of hills around me where I can really test it, but when I put it in drive or reverse with the pedal to the floor, it'll hold the truck from moving (it didn't with the shorter spacers) but when I give it even a tiny amount of gas the truck moves.
Then I thought, well maybe that's not a good test because the 4.0 does have a decent amount of torque. So I drove the truck up on ramps, put it in neutral and mashed the parking brake. Sometimes it would hold, other times it would slowly roll off the ramp.
Anyway, before I just keep making longer spacers, I'm hoping someone might have some insight into this - if I should try something else or just make longer spacers. Or even just tell me that the parking brake will just never be that good with this setup if that's the case :p
At the other ends of those rear cables, where they meet up with the single cable that comes back from the pedal, there is an adjustment bolt/nut arrangement. You can tighten that another quarter inch and it should all be fine.
No adjustment on this one..
Haven't had much luck yet finding a good donor Explorer. I've looked at a few that looked pretty good on marketplace and was told have "no issues" only to find lots of issues/concerns and that the car looks far worse in person. Just gotta keep looking and be patient I suppose!
Here's some small projects I've done in the meantime. I installed a nice B&M diff cover. The diff looks great inside for being pretty high mileage. I wanted to make sure it looked healthy since I will keep this axle at least initially. The plan is to keep the axle from the Explorer and use that once I know what gear ratio I want. The axle in this truck has 3.55 which I think will be a good starting point to know which direction I want to go later on.
Got a nice headunit in. Also swapped the radio bezel out for a fog light one because eventually I would like to swap to a fog light bumper.
And I did a DIY bedliner with 3 coats of Herculiner. I prepped the bed with 80 grit and gold scuff pads. I think it came out decent for a roll in job. I also have bushwacker bed rail & tailgate caps I haven't gotten around to installing yet.
What kind of issues are you seeing in the Explorers you're looking at? If it helps any my '00 5L Explorer I bought to build up seemed to work fine other than the rear spiders were stripped out, turns out after I fixed that 7 miles later the transmission went out and every internal was bad... that was at 206k... at 250k (I used it for a daily driver while gas was cheap) I pulled the engine to freshen it up (had issues where the engine needed to come out to fix motor mount issues) and the dumb thing still had cross hatching on the cylinder walls and the valves just needed faced, this is a very neglected engine too... anyway I was able to just dingle ball hone it with new rings and bearings (did valve springs and cam too) with new cam bearings since I had access to the tool from work, it really just needed refreshing.
To shorten it up, I'm used to dealing with clapped out explorers, I have two V8 explorers so I know some quirks... For the engine I wouldn't worry much if you are handy enough to refresh one, transmission wise is a different story as the stock squishy shifts are hard on things...
Some examples - one I looked at which I was told had no issues, when I got there I scanned the car and it had codes for misfires on cylinders 4&7. It was running pretty rough of course and seemed way down on power from what I'd expect. It also looked like the plug wires were newer so I decided not to chance it on that one. There's just too many things that could cause misfire codes for me to risk it especially when they wanted top dollar for that car too lol. Another one I looked at had a rebuilt engine which I was already a little skeptical about, but that car was actually in pretty nice shape overall. But when I went to look at it, the coolant looked like mud. I couldn't tell if it was a head gasket issue or it was just loaded with stop leak because the guy also couldn't find the key for the car when we had already arranged to meet that day :mad:. I've also missed a few good deals on very low mile ones because someone else beat me to it! It's just been a lot trickier than I anticipated.
My goal is to find one with 150k miles or less and to not have to rebuild the engine. I would just like to replace all the gaskets (short of the head gasket) while the engine is out, along with other preventative maintenance, and then just drop it in. What you said makes me feel more confident though that I'll be able to find a good donor even if the car is rough! I do have one saved right now that's higher miles (around 200k) but it's cheap compared to most I see on marketplace. It's a little higher miles than I want but it doesn't look neglected in the pictures. :unsure:
And as for the transmission that's no big concern for me. If I can find a 2wd explorer I might keep the auto for the initial swap to make sure everything's working properly before converting to a 5 speed. But the goal is to make this a 5 speed truck so even if I did have an issue with the Explorer auto it wouldn't be the end of the world!
While I continue the search for a donor Exploder I've been tackling some of the cosmetic stuff. Got the bushwacker bed rail caps on, and installed a toolbox I found for pretty cheap.
The truck had some minor front end damage which I knew when I bought it - I wasn't too concerned at the time since I knew I wanted to change the grille & bumper anyway. The right side fender was pushed in causing the grille to stick out on the side.
With the bumper off it turned out to be a little deeper than that as the core support was actually pushed in a little bit! Not a huge deal though, I straightened it out with a porta-power and now everything fits better. I wasn't able to get pics of that though as I was running out of daylight.
I replaced the header panel and installed a used Edge grille - which I think looks way better - and some new headlights. I was originally considering getting a powerdome hood as well, but now that I have the edge grille installed I think it looks good with the 2wd aluminum hood. It'll probably be better to save some weight keeping the aluminum hood anyway. Still working out a front bumper.
And I converted to 06+ mirrors, still retaining the power functions too which was pretty simple.
Got lucky and found a great deal on some very nice SN95 Mustang seats and swapped them in. I used seat tracks from a 2000 Ranger from another pair of seats I bought and was originally going to put in this truck until I came across these. It seemed easier to swap the 2000 tracks onto these seats, as it was almost a direct bolt in, rather than trying to mess around with the tracks on the original seats since they're riveted on. Now to find a center console!
Little details - but I swapped the mudflaps out for the newer style rock guards.
The mudflaps wore through the paint in some spots, which is a bummer. So I will have to touch up those areas. I also installed James Duff traction bars.
I also found a great deal on these mint condition pony wheels, and test fit one with the tire size & spacer combo I want to run to make sure there'll be plenty of clearance. Eventually these will be my set for winter tires, and I'm leaning towards 03/04 Cobra wheels for the main set.
Did you ever figure out the parking brake? I just swapped in the mustang brakes on my 2000 and that’s the only thing I’m stuck on.
After I made the longer spacers (shown in the last post on here I made about them) it initially didn't seem like it was making much of a difference. The brake pedal feel also wasn't great after the disc brake swap, there was a lot of dead travel before you'd feel any braking power. However, after pushing the parking brake in and releasing it a lot more times while trying to test it out, it does now seem to be working decent and my brake pedal dead travel also disappeared. I think I read somewhere that these calipers don't self adjust in the same way most calipers do, and that using the parking brake actually adjusts them. It sounds strange but it does make sense how mine is suddenly working better and my braking feel improved. Might be worth a try on your setup.
I will say I don't have a lot of steep hills around me I can really test it out on, but any slight inclines I've tried it on the parking brake does hold the truck sufficiently now. I'm still not convinced it's as good as it can be because I have to push the pedal almost all the way down to the floor to get the holding power. I will have to try it somewhere steeper for a real test.
Also, look back at my first photos of my parking brake setup when I was asking for advice. Notice how the pads hadn't worn all the way through the protective coating on the rotors. The coating is evenly worn off now after I had engaged & released the parking brake several times. Check your setup, maybe you're having the same issue?
Where did you get those rock guards?
I found all of them OEM on eBay. I believe they came on 06 and newer Rangers, so you also could get some off a truck from a salvage yard, you’d just need to clean off the 2 sided tape on the top and re apply new tape. If it helps here are the part numbers from the listings:
3L5Z16G555AAA
3L5Z-16G554-AAA
3L5Z-99292A23-AAA
3L5Z-99292A22-AAA
Replaced the body mount bushings on the truck. The originals were actually in pretty good shape, but I figured it'd be better to put in poly bushings now before the originals become more of a fight years down the road. I was prepared for the worst with these bushings based on all the stuff I'd read on these forums, but these were very easy (perks of a rust free truck I suppose). The only problem I ran into was that the bottom bushing would just spin when trying to remove the bolt, so I ground the head off of the bolts using a belt sander and then just punched them out from the top.
But the most exciting update is... 5.0 donor acquired :yahoo:
After months of searching and looking at a few marketplace exploders and coming up empty handed, I decided to look into other avenues. I bought this 2000 mountaineer from copart. Yes, it was a little bit of a risk since I couldn't go look at the car myself to inspect it (it was 5+ hrs away); but I took my chances because I could tell from the photos that this car appeared to be well maintained, and I was able to get a video of it running from copart. For the price I paid even after all the copart, broker and transporter fees, this STILL came in under half of what most people wanted on marketplace for worse kept vehicles with higher miles. Only 133k miles on this one! I figured worst case scenario if it was a total dud I could probably make back most of, if not all of the money parting it out. It seems to run great and I took it around the block and it drives and shifts well too.
TL;DR - marketplace: 0, copart: 1
Here's why it was up for auction at copart.
The interior is almost flawless in this thing. Also for being from Chicago there isn't anywhere near as much rust as I would've expected. The tires also look brand new, it literally looks like they got in the wreck on the way home from the tire shop.
I totally forgot the V8 explorers/mountaineers came with traction bars. I wouldn't have bought the james duff ones had I remembered I could've just used the bars from this, especially since I'll be using the axle from it eventually too. Oh well. I am really happy with how the bars feel though, I don't think it made the ride quality stiff as I've read traction bars can do, the rear end just feels a lot more controlled.
