88 XLT Ranger
- Jul 23, 2010
- Age
- 63
- Pollock Pines Ca
- Automatic
My on going Saga
Now that the "Urgent Help forum" is shut down it hurts the one's that need help the most. I had Mark, Ron, Jerry helping to figure this issue out the best way they could. Today I had a hell of a time trying to start my truck it turned over slow. I gave it a little throttle as it tuned over it almost fired up. I pulled number 3 and 6 plug out both fuel fouled. I cleaned them and tried again with an extra battery hooked up with jumper cables it fired up it wasn't easy. I did put a filter in line with the PVC a Fram white plastic one but the line is same as a small vacuum line. Today I see oil buildup in the bottom of the filter. My friend gave me a Fram HPG-1 fuel filter canister to use with bigger ID line bigger canister
The darn thing pops misfires bogs now all the time it use to be off and on. I have changed the Ignition Module, MAP, TPS, Ignition Coil cleaned the IAC and put a new Borg Warner dist cap and rotor on and new Napa plug wires. The spark plugs are AP 105's I have changed the fuel filter high valume fuel pump as well. I have also done a vacuum test and compression test all good no issues. I am kinda lost on this and ran out of ideas to fix it any help is very much appreciated
