2.5L ('98-'01) 2000 Ranger 2.5L misfire cyl 4 sanity check
'93BajaSport
15+ Year Member
I'm trying to help a relative with his Ranger that has a pretty bad misfire. It had been sitting with the battery disconnected so there are no stored codes, but the EEC does detect the misfire.
I don't live close enough to do more in-person troubleshooting. While I was there I put a timing light on all the plug wires and both #4 wires showed intermittent spark. He has another identical parts truck that the engine was sold out of. It was described as a good runner and I installed the EEC out of it with no improvement. I unplugged injector #1 and the idle dropped, so it's probably not #1. After I had left, he installed both coils from the parts truck and tried another set of wires with no improvement. I sent him a set of injectors to try when they arrive. I don't think it's a bad fuel injector although the exhaust doesn't smell like gas and it didn't appear to be torching the cat converters, which suggests the dead cylinder isn't getting fuel. :unsure: That intermittent spark on both #4 wires, which means both coils are involved, now makes me suspect the wiring even though I did a cursory look at the coil wiring and connectors and didn't see anything obviously wrong.
What do you think?
If cylinder 1 works fine then it's not the wiring for the coils...
If an injector is lazy it could do that...
Gotta ask. Has anyone pulled the plug from #4?
