- Aug 10, 2014
- Age
- 33
- Madison, IN
- 4.0 V6
- Automatic
- Tire Size
- 215/70R15
Trying to find the cause of a cylinder 4 misfire... and making sure I'm on the right track. 1995 4.0 OHV.
For a long time (several years) I've had a warm start misfire that wouldn't resolve until the O2 sensors warmed up and the EEC transitioned to closed loop (at which point, the fuel trim on bank 1 would skyrocket for a bit). I tried replacing upper intake and fuel rail gaskets (along with fuel injector gaskets) a year or two ago to no avail. I also checked the lower intake bolts and they were tight.
For various reasons (mainly worsening rust), I haven't been driving it a lot the last year or so... but 6 months ago it developed a startup misfire that's become a constant misfire. EEC says it's cylinder, which a power balance test confirmed. My gut feeling says it's either the lower intake or the fuel injector; here's what diagnostics I've been able to do to:
So, plan on doing a lower intake and fuel injector job?
- Confirmed spark
- Spark plug was dry but "glossy"... so hard to say if it's getting fuel or not Plug is not fouled
- Spraying carb cleaner into the air box had no effect
- Spraying carb cleaner around cylinder 4 intake had no effect
- Attempted a compression test only to determine the threads aren't sharp enough... couldn't get it to start in the hole.
- But, I did confirm no galloping when dry cranking (fuel pump relay pulled)... so likely not a major compression loss
- Tried a spare EEC (different catch code, but same hardware and strategy codes), no change.
