BAH!!!!!! F**** One damn problem after another! First the steering shaft is found to be no good cause theres a mile of slop in it. Then the headers dont fit corectly. Then the crank is the wrong size, then the water pump pulley isn't correct. Then the water pump is incorrect. Then the tentioner doesn't come with the bolts. Then the starter goes for a shit again. Then there a wasted day at work. Then I have to renew my plates. Then I have no money to get lift leaf springs cause i need to buy all kinds of new front engine stuff. BAH!!!! I just want to fill the damn thing with coolant and run it for more than 5 seconds.
SO! hopefully the Mustang II header for the drivers side that i origonally had will fit a little bit better than that P.O.S james duff header. If not im going to have to break down and buy the advance adapters headers. Then I've got to get bushings for the trac bar and make some brackets for it, make the third link(STILL). Some bull crap with the front accessories. Then maybe i can make it move under its own power... but only a little bit, just to make me feel better about this whole thing.
I had to get that out of my system!
