my B2
Impressive, and sorry for the thread jack, your rig is awesome NMB2. :icon_thumby:
so last nights working on the truck mostly turned into drinking. However, here are some pics.
battery tray looks good, need to make one myself
did you take the ballistic top and toss it?
no, I used it to trace out onto my other strap.
I made my own 90* oil filter out of the stock exploder stuff.
I pulled the through bolt out of the bolt that holes the cooler onto the 90* fitting.
Cut the threaded/flanged ends off, put the allen key through to make sure they were perfectly straight, and welded them together.
Its not a ballistic peice, but I had an extra skull and they look cool. Finished battery tray/top.
aluminum cover for the 5spd hole. crawlbox shifter modified, and Winters Rock-gate installed, on the trans side as well.
Lookin good man. 11 more days!
I love you B2, any who a random question....what is you MOS?
Thanks.
I'm a 25U, for now. They barred 25U from re-up, so I have to reclass. Don't know what I'm going to choose yet.
i like that shifter, looks good in there
Thanks.
Right on I have a very good friend who is 35F, and one who is 11B
I almost went 68w but decided against it last minute
88M FoxtrotTangoWhiskey:3gears:
keep the progress coming.
got a functional shifter on my rear case, work on prettying it up later
found a lower rad hose to work
alternator
found a belt to work with the A/C delete
pulled old coil out, installed new MSD coil. Will clean out the rest of the unused wires tomorrow
got a throttle cable installed and mocked up so after its wired up, will hook right up
tomorrow I will be getting some packages hopefully. PSC parts to build my pressure line, fuel pump from Summit, and some intake parts.
looking good buddy!
nice progress:icon_thumby::icon_thumby:
l8r, John
