My $3,500 Jaguar - The 'Mad Jag'
Is there any special way I should check the fuel pump? Did you say these things get variable voltage going to them?
reset the computer would be my guess, but I'd trust Bobby way more obviously
I have yet to look deep into the jag setup. It may be a fixed voltage if your lucky.
I am a bit busy....trying to keep from total hair loss..... I have a tool when I get done with this train wreck I can send that may make it easier ...
I have to get this done as much as possible before the 22nd as I have to mobilize a crew for revenue work.
This is the after work work.
Hmmm.
View attachment 72474View attachment 72475View attachment 72476View attachment 72477View attachment 72478View attachment 72479
hmmm. Nice wiring harness. Good luck.
Even rocky....is breaking out the grumpy cat meme.....
I would much rather be working on a Jag in Texas....
Especially in winter ....
Started the Jaguar today and it's idling fine now for some reason.
Went to Harbor Freight and picked up a Basic Fuel Injector Service Kit so I could measure the fuel pressure with the key on, and then with the engine running.
72713
When I got home I discovered that Jaguar apparently did away with the Schrader Valve on the fuel rail after 2003. Sum Bitch!!
72719
So..... not sure how I'm going to check the fuel pressure. My guess would be to disconnect the hose going to the fuel rail in the middle of the photo, and somehow insert the T-fitting that's in the kit in between there to connect the pressure gauge. :icon_confused:
I think that's exactly how you do it.
Looks just like a normal spring lock coupler... there are proper adapters for that very thing. might be able to rent one from the parts store.
Well...that would certainly relieve the pressure,
I don't know how similar the 04 is to yours but I found this thread that links to other threads. It seemed similar to yours...
xj8 x350 4.2 NA fuel pressure regulator - Jaguar Forums - Jaguar Enthusiasts Forum
Thanks for looking that up.
When Bobby was here we were looking it over and noticed that the platic fitting for the vacuum line going to the fuel pressure regulator sensor was broke, so I replaced that sensor with a new one.
It's to cold to work today. When it warms back up I need to pull the rear seat up and check the connections at the fuel pump, figure out how to test the pressure, and then order a new pump if everything else checks out.
Do I dare ask how cold is too cold to work?
in texas? im guessing 60- which is what we had here in ohio a couple of days ago. Its 22 right now.
It's 19 degrees right now. ☃
Featured Ranger Based Vehicle
