Mechanical or electric fuel pump?
Featured Build Threads
allpau2thou
Haleiwa, Hi.
I had to redo the fuel lines in my 302 because the way I had done them was leaking. I have a carbureted motor and was trying to retain the stock in tank pump in my ranger which is a 40 psi pump. I was using a regulator but the pressure was too much and the regulator was leaking. I decided to replace the pump and by default went straight to an electric, mainly because I didn't understand the mechanics of a mechanical fuel pump. I was reading through the tech forums and saw that the fuel pump from a 70' Econoline works so I googled it and found a lot! For cheaper than an electric too. So I youtube'd how they work and am kind of a throwback junky so now Im more interested in the mechanical fuel pump. The question is now can I convert to a mechanical pump? My motor came out of a 90' F150 Custom and was originally fuel injected. I converted it to carbureted but Im not sure if the block is made for a mechanical fuel pump? Does anyone know if my motor is compatible with a mechanical fuel pump? I tried looking but I can't really see where I think it goes... Thanks for the help. If no one knows Ill probably continue with an electric. Aloha, Aaron
on a mechanical pump is turned by the camshaft. so u would need all the parts for that and u would need a timing cover that works with the mechanical pump. here are some different covers they make.
Sounds like the wrong regulator, did you use a return style? I found spring-loks for my factory lines into a return style regulator and never had a problem running the factory pump setup. I would stick with low pressure electric pump, but just my opinion. Either way, you are probably going to have to drop the tank, take a check valve out of the return and use that as your feed.
Perfect, thats exactly what I was looking for. Thanks. Unfortunatly I don't think my motor can use a mechanical. Thanks for the help.
I pulled off the bed. I have access to the pump.. The idea of using the return sounds good to me. All I have to do is remove the check valve and it should be ok?
It's probably not worth going mechanical unless your engine already is. It's a tight fit with the steering box and you might encounter problems with the FEAD. I'd rather change an electrical that's placed in a good spot, versus a mechanical in a 5.0L swapped Ranger, but just thinking out loud and just an opinion.
Yup, the issue is the pump in the tank, can't use the regular feed line since the pump is inline, in the sending unit assembly. Using the return as the feed gets you directly into the fuel in the tank.
Sounds good. Thanks. I'll work on it tomorrow and post how it goes. Trs to the rescue as usual
Featured Ranger Based Vehicle
