Wanted Manual BW4406 SOCAL area
Maui-sprint
Oahu, Hawaii
Will be in San Diego next week in search of a transfer case for my 302 build. Truck is a 1989 short box. I have an electric 4406 already but it is a later model without speedo.
Looking for a manual 4406 with speedo cable, I believe they came in the '97-98 F150s. Any leads appreciated.
if you do not find one, i have a "brand new" bw4406 manual shift w/o speedo leftover that i will sell cheap....612-309-3999
Ok I may entertain that if I cannot locate one. But I will need to figure out how to convert it to accept a speedo. Would have to locate a tailhousing or machine the existing. What are you asking considering I have to ship it back to Hawaii?
Shoots. Let me check shipping from MN to HI. Unfortunately that wont be cheap! I will text you at the number you provided after I look into shipping. Let me see how much $ I'm looking at to get it over here. Definitely interested.
Have you tried: https://www.car-part.com/
Good site for local used part
1997
Ford F150
Transfer case
Skip areas
YOUR Zipcode
Search
New window
select "Warner 4406, manual shift"
Search
Got lots of hits using LA Zipcode
Make SURE you get ALL the manual linkage and boot for cab
I have not tried that site but just went on and did a search. It provided me with a good list of junkyards to call in cal. Thanks!
On a separate note, do you know if the manual shift linkage from a BW1356 will work with the 4406?
The M5R2 I'm using in my build came with a 1356 (including all linkage). I'm going to try and see if I can make the 1356 fit but from what I've read on TRS and measured Im not expecting it.
Going into an '89 standard cab SWB...
Not sure on shift linkage match, but I would agree, it would probably not be the same
