m5od-r1 help please
rmn42689
Jeannette,PA
how do u disconnect the clutch line that comes right out of the transmission?
to connect it you just shove the two pieces together.
It should be noted that there are black and red connectors used in '88-92 Rangers
and "yellow (or gold) connectors used from 1993-up and the red/blue/black connector is NOt compatible with the later "gold" connector.
It'll kinda go in but won't latch in and stay in
AD
if you are replacing the slave...then you can just rip it out....it bends the spring tabs over and comes out, but you wont be able to reuse the slave.
simply "yanking it out" can dammage the male part of the quick connect
and create a requirement to also buy a $50-$75 clutch line in addition to the slave.
AD
