LS Swap
Featured Build Threads
nightstalker00
In a house
Started life as a 2wd 94 Ranger Splash extended cab with a 4.0 and an automatic. The engine and trans have been removed. Then I swapped in a D44/9. Right now I am working on cleaning up the under hood wiring, by removing anything I don't need. The way I started looking at it all I needed to retain was wiring for the lights, wiper motor, horn, and rear electrical connectors. I'm looking for someone to help me ID some wires in the c105 connector. I have 19 wires that either came from the engine harness or from the PCM. I have figured out the pin# circuit# and wire color, but I am unable to ID what their purpose is. For example: pin 35-circuit 12-LG/BK, pin 36-circuit 932-GY/W and so on.
More to come and I'll get some pics up.
LS SwapLS SwapLS SwapLS SwapLS SwapLS SwapLS SwapLS SwapLS SwapLS SwapLS SwapLS SwapLS SwapLS Swap
Check the tech library for the EVTM(electrical and vacuum trouble shooting manual).
Once you install a chebby engine into a Ford you'll no longer be allowed to wear men's clothing.
Figured it was time for a change. I've already put a 302, 351w, and 460 in a ranger/bronco ll.
Got all the excess wire cleaned out. I even saved the fuel pump relay and wiring. Just need to hook up the trigger wire. I even added a circuit for fog lights. Just need to add a relay for pcm and fuses for coils, injectors, and o2's.
Event Coverage
Featured Ranger Based Vehicle
