bflooks
- Aug 15, 2007
hey guys, not sure who is still here from a year and half ago, but if anyone can help me out, it would be most appreciated. allow me to give some background on the whole situation...
i am a toyota guy to start, so ford/mazda's are new to me...
a year and a half ago, 3 of us attempted to get a mazda b2300 (1997) running after it had sat up in vermont for 3 months. after many weekend trips up and working on the truck in 20 degree weather, we finally got the timing belt replaced (thanks to advice given here) and got it to start for about 10 seconds. new problem was that it wouldn't start again, so we left it for the rest of the winter up there and towed it to mass. this spring. we were breaking in to doing all 8 plugs, wires, etc. to figure out the cause, and ended up having to remove the head because of a snapped plug on the primary (intake side). all that is fixed and the truck is back together now, and the timing tensioner spring has been replaced as well. so now we are current...
when trying to crank the motor over, we are not getting any spark. fuel is going, the engine is turning over fine, but that is it. we have tried arching the wires and coils and there is NO spark at either coil pack. with the ignition in the on position, there is power at the center pin on the plugs. we have a haynes manual, and it says to check the packs, which we did, and both seem to fail that test. what are the odds of this?
we have also read somewhere that a bad crank position sensor and a bad cam position sensor could cause no spark. same goes for a bad ecu ground, but this has been ruled out.
any and all help/suggestions would be MUCH appreciated! we are sick of working on this truck now, and it is so close to being running again... we could really use some of your expertise to help save ourselves from wasting time on foolish possibilities.
