Vehicle: 2001 Ranger 2.3L/5 spd with 125000 miles
Problem: The truck recently sat for about 4 weeks. When I went to start it, it just clicked like the battery was dead. I checked the battery, and it was low, so I charged the battery and everything seemed normal. Cranked and fired right away. I dismissed it as being a side effect of sitting.
Everytime since then however, if the truck sits for any moderate length of time (more than an hour or so), it acts the same. Turn the key, lots of relays clicking but no crank or start. If I hold the key in the cranking position however, it will eventually crank and start normally. Once it's started, everything is normal. No dimming of lights, or stalling sputtering of any kind.
When the battery is freshly charged, there's no problem. I had the battery tested at the local parts store, and their tester initially wouldn't recognize that it was connected to a battery even after several attempts. They tried a second tester and the same thing happened. They moved to a third tester, and proclaimed that the battery was good and had a full charge. I'll take the battery to a different store to see what they say before I buy anything new, but haven't had the chance yet.
So, what do you guys think? Am I dealing with a weird battery issue that could be easily fixed with a new battery? Some type of draw that is draining the battery when the truck isn't running? Something else? Talk at me.
