- Oct 7, 2021
- california
- 2.5L
- Tire Size
- stock
I always wondered why you cant change fluids on a vehicle by just replacing small amounts at a time. actually seems like it would be ideal for replacing the ATF on a high mile automatic transmission with a questionable service history...
so I have a 2nd gen prius and it says I need an expensive computer tool to completely drain and replace my brake fluid. why couldnt i just drain a couple oz out of the reseviour(sp?), replace with fresh fluid and then drive around, and repeat the procedure a few more times over the next couple thousand miles? i know it wouldnt be the ideal way to completely clean the system and remove trapped sediments that sunk to the bottom, but at least it would improve the quality of the fluids within the brake system, ya?
