Jeep Rims on Ford ranger?
Dprocks100
10+ Year Member
Salt Lake Utah
Ok, so im new to the forum, and i have a Question. I have a 1991 2wd Ranger without a lift. I bought some 15x7 jeep rims thinking they would fit and didnt think about the backspacing on them. they have a 5.25 backspacing. Im looking for an aggressive look and was wondering if i would be able to use them, and if so, what would be the biggest tires i could put on with the least amount of rub without using spacers. Has anyone done this?
-Dallin
Welcome to the forum. What Jeep are they supposed to fit that has 5.25 backspacing? I thought they were 3.5 to 4.0 depending on rim width.
Stock Ranger rims are your only real option(from a yard), Jeep rims are all baskspaced too much. stock backspacing is typically 4.5" for Rangers, and if anything you want to get less-backspaced wheels, not more.
They'll work. You'll very likely get some rubbing when turning on the sway bar or on the frame. I've seen several Rangers running around with Jeep rims up here in Michigan.
My spare tire is a jeep rim, and I did test fit it first. My original 2wd 14" spare wouldn't fit over the 31spline 8.8 hub-thing, so I had to find another solution. Fit front and rear just fine.
for a 1991 2wd, your probably looking at 235/75R15 as the biggest with absolutely no-mods.
ok, thanks guys! They are late 90's Cherokee rims. I put one on the other day to see if the rim its self rubs and it doesnt so im probably going to try some 235/75r15 on them and see how i like it. I dont really mind if it rubs a little just as long as its not a ton.
