yah chians snap . . . a strap will give yet they have enough strength . . . good luck
. chains are ok but id rather have the strapwell ?.?.?. it's been a week n nothing ??? what happened ?????????? did u do it ?? did u forget to video tape it ?? what happened ??????\
i wanna know . . . .
What did he do? Flip it, then go after every mount with oxy and a hammer? Seriously how do you break everything in the front of your truck?
We did'nt do it because the day i got my truck back, he totaled his HEEP. He went Wheelin' too fast and broke all his shock mounts, sway bars and tie rod ends, and all the other mounts in the front end that are criticaly inportant.
THE HEEP IS FINALLY DEAD!!![]()
For future reference, DO NOT USE 4 LOW!!!! I did and you should see how much it ended up costing me. It will FRY the planetary gears in there. The planetary gear assembly alone is $200.
For future reference, DO NOT USE 4 LOW!!!! I did and you should see how much it ended up costing me. It will FRY the planetary gears in there. The planetary gear assembly alone is $200. Best idea is to never get in a towing contest unless you have a half ton or larger. Straight front axle too. Pulling contests SUCK. My two buddies did one the other day with a 79 chevy 4x4 and a brand new or slightly used ford powerstroke dually 2x4, and it ruined two tires on the dually. Just go hill climbing or mudding dude, I'm serious. The chance of you messing something up probably is 10 times more likely at least. Like I say, If you must do it, do it in a noncritical vehicle or clunker. Not a good ole' ranger unless you have some serious mods.
well...
this is bad, dont know where to start. almost the whole thread is bad info actually
but, when doing stupid shit like this...which i do often...low range is the only way to do it. if you dont automatically understand this then you shouldnt even post advice....axles/driveshafts/lockouts are easier to fix then tranny innards...low is the only way to go...unless you both go hi/2wd or whatever. low is best for the vehicles.
you just dont simply use the brakes either...its more complicated then that. its part of a tactic....you go ahead and just apply the brakes with me CHAINED or piped on to your ass and your done dude...easiest way for me to win. cause your easier to drag...unless its super loose wet/clay base or mud that can divot. terrain is everything as to what tactics you use....automatics are easiest to do this with as well for different reasons then what is obvious.
that said theres no way you were beating that xj unless it was wasted.
as for the fried planetaries.....t case or tranny? cause you can take a good running set of fords and do a few reasonable pulls without even the least bit of worry...the ford dealer has brought lot trucks down to belleville events, just to show they got the balls to drag the 24k sled with ease...so i think there may have been wear issues already present...then again i didnt witness the event , theres a reasonable point to stop...and traction usually ends that long before small tires can bust something.
and yes....i am stupid...and i do bust everything. but all i have to do is ease up...and wheres the fun in that...![]()
