Jaydang
I have a 88 ranger 2.9 engine in my 84 bronco ii. it has a horrible idle loop that kills it almost immediately at stop light when warm. Ive replaced the map sensor (multiple times), the ECU, distributor, egr sensor, and most of the wiring under the hood. when the map sensor is unplugged all my problems go away. So i checked the wiring and i have 5v between the positive and negative on the map and 100-104 hz on the signle wire at idle. The base timing is set to 12 and it has headers and a cold air just incase that helps. Ive been through 3 well known mechanics and im over 7 grand into this thing with not much to show for it. Please an ideas you guys have will help immensely. Thank you
Also now that im thinking about it. It has 140 +/-4 psi on all cylinders and has 38 psi of fuel pressure. Also it has 20+ on the vaccume gauge.
