I'm sure I got a short.
So in other words I need to do the test we've been talking about no matter what.
I just tried looking for a slosh module on Amazon and it kept charging it to SPLASH.
Is it just slosh module or is it anti slosh module?
anti slosh module - and they are repairable (replace the capacitor which is usually the only thing wrong) and even bypassable
if you bypass em then the gauge will act like an old 60's camaro.... you step on the peddle and the gauge goes down , bounces around ... corner it bounces around again.
I shared this one before - how to bypass/disable the module:
if you got an extra 15 min this is a guy going over the schematic and diagnosis and explains a lot of the little nuances of the schematics:
Good video Brain.
Okay I'll watch that one now.
I liked that video too.
But what does he mean when he's talking about the POT he's going to make and hook up?
Rather than diagnosis it via a tester (meter), he chooses to diagnose it through substitution (building a "pot" - potentiometer in the right 16-160 range that acts just like a fuel sending unit and then substituting it) in place of the fuel sending unit (hooking it to C118)....
If you rather "just fix it" you can spend 15 minutes diagnosing it with a meter, if you want to build things for the fun of building electronic gizmos - you can do what he did and spend 30 minutes doing the potentiometer math, then another 10 building a circuit, then 10 more testing by substitution.... my vote, spend $5 and get a DMM from harbor freight..
Okay you got me.
What does DMM stand for?
Digital Multi Meter - same thing as what you got, cept you got a nicer one than a Horror Fright junker
I got mine from Harbor Freight.
It cost me 19.95 plus tax.
After watching your video I'm thinking with all we've talked about. Along with the symptoms the truck's giving me. It might just be easiest and fastest to pull the instrument cluster and by pass the sloth module.
I didn't notice that type-o. I meant slosh module.
It was funny though.
Okay I'm going to go to bed.
Thanks again for the help Brain.
Thanks to everyone else as well.
Event Coverage
TRS Merch
