I blew a brake line.
Featured Build Threads
Deep Gap
NC - USA
Other
1997 and 2001 Mazda Miata
Vehicle
Drive
standard
2008 4.0 4wd. Couple weeks ago I had to slam on the brakes for a deer, thankfully I didn't hit it but I did blow my front right brake line coming from the ABS module. I have looked online and found nothing that looks like the line I have taken out and my local junkyard was no help either. At this point unless one of you can direct me to the specific brake line I need to buy (I don't think anyone sells it, I've checked with a ford dealership and even they cant get it.) then I will need to make my own brake line to replace it. How hard is this? I've never made a brake line and it seems somewhat straightforward but the consequences to being wrong are pretty steep. If I do make my own line there's no way I'm getting all of those bends in it to route it through every clip I had to take it out of. Has anyone replaced this line specifically and where/how did you route it differently?
I just had a rear brake line blow on a van that I have. It seems all the OEM's go crazy with all those bends, I have always found it unnecessary to copy all that.
First off, find out what size the line is and what type of ends are on it. The particular van I have had bubble flares with metric ends. But the line was still 3/16, go figure. Most older cars and trucks have the inverted flare ends(look like a speaker cone).
What I did was eyeball where the line was going, and roughly measured with the measuring tape the length I needed. I figured 5ft would make it, and it did. It just so happens they sell a universal piece of Ni-copp brake line at the parts stores, with the bubble flare and proper metric nut already on it. They also sell universal lines with the inverted flare. The 5ft line worked perfectly, missing all those crazy bends, but still was able to use most of the mounting clips.
If you want to flare the ends yourself, you will need the flaring tool and you can get a roll of Ni-copp off Amazon. The reason I keep recommending the Ni-copp (nickel copper alloy) is it doesn't rust, and it is so easy to bend by hand. You can fish it through the truck, bending it as you go, it routes and bends like stiff wire. And another plus, it does not rust.
Glad your OK.
Making your own lines isn't difficult, there are many videos online that go over the procedure.
Out of curiosity, do you go off-road?
I've learned sooooo much and made life-long friends at my local wheeling club.
I would check if any are in your area...you will thank me later :)
Yeah, it’s not hard to make new lines and typically you don’t have to follow all the factory bends. On lines that are particularly hard to install in one piece I’ve even put a fitting in a convenient spot so I can do it in two pieces.
You do have to watch when buying Ni-copp lines, some of the listings you find on Amazon and the like are copper coated steel and not true Ni-copp. A magnet won’t stick to true Ni-copp. Also, I prefer to buy stainless or brass fittings to use with Ni-copp with all the corrosion issues we have here in the rust belt.
Yes,, that is one thing I did notice, the universal lines come with threaded nuts that do rust. Usually doesn't create a hazard to the line, but just a aggravation if you have to take it loose later on.
Yes,, that is one thing I did notice, the universal lines come with threaded nuts that do rust. Usually doesn't create a hazard to the line, but just an aggravation if you have to take it loose later on.
I’ve also started to use a dab of copper anti-seize or grease on the tube where the nut sits and on the threads. If I ended up having to use a regular steel fitting I’ll paint the whole thing thing after it’s together and tested with a grease/oil mix I make.
inline tube can probably make it for you.
May have to buy a whole set.
Thread title reminds me of this joke.
A penguin takes his car to the shop.
Mechanic looks it over and calls the Penguin over to tell him the diagnosis.
Mechanic : Looks like you blew a seal.
Penguin: wipes his chin " It was just an Ice Cream Cone, I swear!"
Event Coverage
Featured Ranger Based Vehicle
