How many bolts on thermostat housing 2000 Ranger?
bigtrucker
2000 4cyl 2.5 ranger
temp gauge always at or below cold
barely any heat coming out of vents
engine warning light is on... Autozone says the code is low temp reading
so, I'm thinking the thermostat is just stuck open. But... I only see 1 bolt on right hand side as I'm looking at the housing where the upper radiator hose meets it.
Is there just 1 bolt? would seem like there should be another one on the other side, but I can't see... do i need to take other stuff off to get to it?
Might check the with the guys on the 4 cylinder forum. These symptoms can also mean an air pocket in your cooling system.
Yes, you should have posted in the 4cyl forum.
You should be looking at 2 bolts at least.
Another thing, is your coolant full? Have you had any cooling system work done recently?
