nwsac
- Apr 10, 2014
- Manual
- My credo
- Fords and Toyotas have been good to me
I have a 3.73 limited slip 7.5 differential. I have to pull out the pinion gears which are visibly worn. Had major problem with the axle grinding so new problem was in the differntial.
My Question: How do you remove the axle rods? I have removed the pinion bolt and have this S clip in middle that must be removed. There is a sliding bolt in middle that is hitting the ring gear. How do you remove the axles? My goal is to rebuild the differential and am trying to do economically, I will try and upload the pic, but dont have a url
