got a piece of chalk and a straight line to test it in? my vote is the squished tire will rotate more, and generate more heat.
(BTW, circumference = pi x diameter)
Sorry. I’m not convinced. Where did the extra rubber go? Why don’t we recalibrate our speedometers for heavy loads? The axle is closer to the ground. But the distance around the tread has not changed. We just Chang the shape from round to “D”-shaped. That measurement from pavement to axle is not a true radius because we’re not talking about a circle. If you measure from the axle to the top of the tire, you will find that the radius has not changed.
This is why we should all run 10 plys.
Quite a few years ago NHRA was trying, once again, to slow the top fuel cars down. They imposed restrictions on tire diameter, gear ratios, max engine rpm. I think they were trying to limit them to 320 or 325mph. By all the calculations, it should have worked. The next weekend Tony Schumacher ran 330+ mph. Long story short, they were running a 14" wide rim instead of the normal 16" wide rim. That allowed the tire to "grow" a little more. Which, in turn, gave them a higher top speed. No one cut the tire and added anything too it, the rubber just did what rubber does... it shrinks, it stretches, it conforms.Guys. I’m not trying to get anyone upset or worked up. I’m willing to learn something new. My brain is hung up on the fact that for a 30” tire, the manufacturer lays a strip of tread rubber about 90.25” long around that tire. So it seems to me that that tire must travel 90.25” for every revolution unless we cut some of that out and glue the ends back together for a smaller tire. That’s just my hang-up. Y’all just ignore me and go on with life. I’ll be ok. ?
Or 45 or lower aspect ratio tires which have no sidewalls to compress.
We're not missing that, it was explicitly covered earlier. The current drift of the conversation was based on a comment about straight driving being an additional issue based on drivetrain weight.Everyone is focusing on the wrong tire rotation difference issue and 4X4. The issue is the difference in tire rotation of the tire on one side of the axle and the tire on the other. If a truck is traveling in a relatively straight line, there is not problem.
The problem is in a turn where the outside tire needs to spin more than the inside tire to cover a longer distance. With the front and rear axles locked together, the system will bind up and something needs to give to relieve the binding.
On dirt and gravel, this isn’t a big problem since the dirt or gravel will provide the needed slip to relieve the binding. Pavement doesn’t provide that slip. Add in an engaged locker and the problem is compounded even more.
That is the issue of concern with the problem the OP may or may not have.
My wife did the same to my truck years ago and it has been fineThrough a convoluted series of events that I don't fully understand, my brother drove my ranger about 6 miles on the highway (dry pavement) in 4wd low. I'm assuming at regular highway speed (55'ish miles per hour) but details are sketchy.
Me: Didn't you notice it was in 4wd low?!?!
Him: Well, I did have to give it a lot of gas....
I can hear an exhaust leak now; maybe from getting hot and shook to hell; maybe unrelated. Anything else I should look for? Years off the life of my tx case? I took it out on a dirt road, and 4wd seems to work fine. But I rely on this vehicle for work, so I'm willing to preemptively swap a part if it prevents an on the job breakdown.
It's a 98 3.0 automagic. I ditched the PVH and went with live axles, so yes, the hubs were definitely engaged :/
Thanks,
Cahman
