Can I run 4wd on highway?
86ltrain
Northern MN
I'm new to the forum, you guys have alot of very useful info on here...I like the Tech Library...Anyways i've owned many 4wd's but have read that you are not supposed to run these Rangers at highway speeds in 4 wd? It never hurt any of my other trucks. I'm in the process of buying a '93 w 4.0, 5spd manual, elec shift 4 wd...I live in northern MN so I do need 4wd on-road occasionally, never dry roads of course Whats your opinion?
Welcome to TRS!
I don't see a problem with what you're talking about so long as your gearing and tire sizes are the same.
Enjoy the site!
Allen
It's dry pavement that hurts it.
You can run it on 4x4 High at highway speeds, as long as there is sufficient slippage. You don't want to be in 4x4 when the road is dry. You are supposed to be able to shift on the fly at any speed up to 55mph.
And the "up to 55" as far as I know is becuase even the slightest turn of the steering wheel at higher speed, can cause the gears to not mesh right when it engages. It may be very slight, but enough to cause the 4wd shift to not work, and grind, or what ever it may do.
Personlly, I think, if you need 4wd, you shouldn't be going 55. Just my oppinion though. 4wd is for bad conditions. High speeds are not for bad conditions. That's what I believe and I will go by it.
In order to shift on the fly, you need the hubs locked in proir to shifting right? Like, lock them in when you leave on a trip and if you need 4wd, then you can shift in while moving? Otherwise, the front drive parts are not spinning and will have to start moving FAST right?
well u also gotta think about how all-wheel drive systems work. im not exactly sure how similar they are to 4wd(maybe a different type of transmission) however, if u run open diffs, u should be ok.
No, the reason not to use 4WD above 55 MPH has nothing to do with gears meshing.
The reason is that a part-time 4WD system guarantees that at least one wheel slips on turns, and this really is not a good thing at high speed.
My 94 ranger was running at 4wheel drive on the freeway for a road trip because the electric shifter is messed up and the hubs got so hot all of the wheel studs on the front passenger side sheared off except one all at once going 80mph downhill. The studs broke off 1/2" inside the disk brake hub. Only thing holding the tire on was one lug and the warn hub. the bearings barely turn now.
