Hi all! I'm new here so I apologize in advance for any formatting issues. So, I have a '96 2WD Ranger XLT with a 3.0 V6. The problem I'm having at the moment is pretty significant vibrations at highway speeds as well as a slight pull to the right at any speed. These issues only started within the past month or so. I've already had work done on or personally replaced several components that other threads said could be causing the issue.
I had both my U-joints replaced by a shop a little over a year ago, and within the last month I've replaced my rear wheel bearings and axle seals, brake shoes and drums, front brake pads and rotors (I didn't replace the front wheel bearings, but they seemed fine when I did the rotors), sway bar links, and all four shocks. I also get new front tires about 6 weeks ago and new rear tires this week, and an alignment pretty recently. The only notable issue with the tires is that the front right tire was starting to separate according to the shop where I got my tires replaced. Also, the passenger side sway bar link was broken clean off at the sway bar.
The only other diagnostic ideas that I've run across are that the driveshaft could be out of balance or that the ball joints/control arms may need to be replaced, but any advice or words of wisdom would be greatly appreciated!
