Help needed with front axle and diff disassembly
Lithuania
Hello, I am currently restoring my Bronco II '88. I'm trying to take the front axle and diff apart due to the fact that 4wd doesn't work and movement of steering causes strange noises. When I tried to take it apart I couldn't get past the removal of the spindle, it seems to be stuck. Do you have any suggestions on how to dismantle it completely and maybe share where can I find the parts required for reassembly? Thanks!
74179
74180
74181
74182
There is a C-clip that holds it in, there is a thread or article somewhere on this site explaining how to remove it and how to replace it with a spring. Requires removing the diff andf "banjo" housing. That is the axle shaft, the spindle is what you removed to get at the axle shaft.
This is not accurate. The C clip you are referring to is on the passenger side and there would be no spring in there from the factory. This person's pictures indicate that the driver's side is the area in question.
You are missing the universal joint and both axles shafts are junk. Normally you can just pull both shafts out of that hole in the steering knuckle (what you referred to as the spindle, I think.) but since the universal joint is gone and the shafts are damaged, you may have to use a grinder to make them fit. Don't worry about damaging them, they are trash at this point. For what it's worth, the "spindle" is already removed in your pictures... it was the round part that you would have removed in order to see that big hole in the knuckle.
I am not sure where to suggest looking for parts. I cannot imagine that those trucks are common in your part of the world, do any local junkyards have one (or a 1983-89 Ranger) that you could salvage some parts from? eBay maybe? They inner and outer shafts that you will need to fix this are fairly common in the USA but I don't know the logistics of getting them to you.
You also need to remove the spindle from the ball joints(replace these) to get the axles out
The driver side axle shaft will pull straight out of the differential. They can be difficult but a good pry bar is your friend. In the event of a failure they sometimes twist at the splines making extraction difficult.
The passenger side has three shafts. The outer two will separate from the inner one but you will have to remove the clamps at the rubber boot on the slip joint. To get the last inner shaft out you have to remove the differential. Push the axle in and remove a C clip then the axle will come out of the differential
Parts may be difficult. I’ve got a few sets out in the barn but you way way way over there. Good luck fren.
Edit: If you need further information hit me back. Like I said I’ve got a couple of them in the barn I’m sure I could mock up a video to demo for you.
Welcome to the site.
This.
Alternatively you could remove the entire knuckle instead of cutting and beating on the axle shafts to get them out through the hole, but they are indeed trashed. If you plan to replace the ball joints, the knuckle has to come off anyway.
When you take the differential off the beam, drill a small hole from the inside of the housing into the lowest bolt hole. That way you can use it to drain the oil later without taking it all the way apart again.
"explaining how to remove it and how to replace it with a spring."
REPLACE
It was accurate.
As to the original poster, in the best of times getting a replacement shaft would have been iffy. Here in the USA, even brake boosters are out of stock with long delays, having to be ordered from the "factory". It is one reason I decided to upgrade my B2 to F-350 brakes, the parts are still available on the shelf or the next day.
I would suggest you keep your shafts, make exact measurements, and have the ends replaced with some easily resourced local UJs, even if it means using something such as a CVJ from a Subaru or something. I think I used Jeep or FSB ones in the past (20 years ago). When modifying destroyed shafts, what I have done is weld on small plates over the cap holes so the cap can't pop through since milling the ends to retain the UJ was out of the question at the time. Most large truck shops can balance driveshafts and axle shafts, that is where I used to get mine done when I lived in a snowy state and used to drive at speed in snowy and icy weather and did not want vibrations.
