- Oct 21, 2008
- Manual
Axles:
Edited to be eligible for OTOTM nomination.
Closest thing I have to an off road picture right now.
This was my first axle swap, if it's worth doing it's worth over doing
. I'v been daily driving it and hitting a few light trails and OHV parks and now I'm to the point of tuning my suspension.
This was the first time I flexed it with a forklift and well.....frankly I'm disappointed. I thought it would flex more. And I'm sure it will, hence the tuning. All the pictures were taken with the truck in the same position. No sway bars and no anti wrap bar.
This is as high as I could get the front before it started to lift the driver rear tire. 30" from bottom of the tire to concrete.
Front drivers side spring, starting to go into negative arch just as the shock bottoms out.
Front drivers side shock, just about bottomed out.
Just starts to rub the fender as the spring starts to go into a negative arch/shock bottomed out.
Front passenger side shock, still has more stroke to give. How much? I don't remember.
Front passenger side spring, I think it will drop out more. Maybe another 4-6".
Rear drivers side spring, will drop out at-least another 6", but shock is topped out. I'm using the stock rear shock mounts.
Rear passenger side, obviously need to trim the fender, shock is bottomed out.
So.......advice? Obviously trim the fenders, and......add bump stops?
-Jester
- Front: High pinion Dana 44, Lockright, Alloy 4340 shafts, 5.13 Yukon Gears. Ballistic diff cover.
- Rear : Dana 60, 5.13 Yukon Gears. Locker and Alloy shafts to come. Ballistic diff cover.
- Front: Rancho 44150 springs with a medium add-a-leaf, 4.5" shackle.
- Rear : Skyjacker 6" softride springs, 2" block, Belltech 6400
- Total lift: 7 inches.
I don't think those were 6" Skyjacker springs.
- 37x12.50 Goodyear MTR Military OZ
- Random Skyjacker and Rancho's that I found in my dads shop.
- Soon to be Bilstein 9100 series
- High steer.
- 100" wheelbase. Pushed the front axle forward 6".
- Custom multi-mount front winch/receiver with stinger bar.
- Hella 700FF driving lights
- Smittybilt XRC8, with Viking Offroad Amsteel Blue synthetic rope with safety thimble.
- [Jeremy Clarkson]MORE POWER!!![/Jeremy Clarkson] Build the 2.9 w/ supercharger, or 4.0, or 5.0 swap. I haven't decided.
- Cage
- Ruffstuff light bar. Should pick that up next week sometime.
- Flat belly
- Boat sides or sliders
- Rear bumper/tire carrier
- Doubler
- Rock lights
- Maybe push the rear axle back 4"-6".
-Jester
